AStewart Posted July 11, 2008 Share Posted July 11, 2008 I am trying to join some walls of the same type. The wall join tool will join some walls, but not others. I don't get an error message or anything it just doesn't work. What am I missing? Quote Link to comment
Guest Wes Gardner Posted July 11, 2008 Share Posted July 11, 2008 Same layer? Can you attach the file so we can try? Quote Link to comment
brudgers Posted July 11, 2008 Share Posted July 11, 2008 Are you trying to "L" join walls in "T" mode? Quote Link to comment
AStewart Posted July 11, 2008 Author Share Posted July 11, 2008 I think I figured it out, I had the capped join mode on. I seems to be working now. Sorry guys Quote Link to comment
beanus Posted July 11, 2008 Share Posted July 11, 2008 I get this problem quite alot & I find that if I use the "remove wall breaks" tool on the junction that won't join & then shorten the wall length with the mouse & I then rejoin the walls with the tool, this usually works. The attached pdf shows one that gave me alot of grief but it eventually worked with the componant join tool. Quote Link to comment
