Daryl Wood Posted July 9, 2008 Share Posted July 9, 2008 I am having difficulty setting up a custom tool script. Maybe I'm not understanding the limitations of the functionality in VW. I want to set up the repetitive unit tool to use a certain symbol and settings in the object properties dialog, and set a specific class active. I then want to execute this custom tool script and get to drawing with all the correct settings. Trouble is, using the custom tool tool does not set the a current class or the correct tool, it wants to set the "massing model" tool active. Nothing seems to work like I think it should. What am I missing? Quote Link to comment
Jonathan Pickup Posted July 9, 2008 Share Posted July 9, 2008 if you want to use the custom/tool set the tool you want, the attributes you want and all that stuff. then use the Custom Tool/Attribute command. it will set up a script for the current tool you have selected. if you have my Architect Tutorial manual you will find instructions in the appendix for this tool Quote Link to comment
Daryl Wood Posted July 9, 2008 Author Share Posted July 9, 2008 Hello Jonathan, I think your missing my point. I understand how to use the custom tool/attribute command and I don't need a book or tutorial to tell me how. VW2008,sp3 does not seem to work with the repetitive unit tool. Probably because vectorscript does not have a toolid integer to identify the repetitive unit tool. Thanks, Quote Link to comment
Jonathan Pickup Posted July 10, 2008 Share Posted July 10, 2008 i see there are a lot of tools that this applies to Quote Link to comment
