mmyoung Posted July 5, 2008 Share Posted July 5, 2008 Is there a way to hide things in the design layers? *Frequently* I want to do that. I make do by locking something or moving it with the Move tool a specified amount, like 6' or something, to get it out of my way. Is there an easier way? thanks ?Michael Quote Link to comment
mike m oz Posted July 5, 2008 Share Posted July 5, 2008 If you are using Classes for the different elements in your file you can switch the Class Option for Visibility to Grey/Snap Others or simply turn the Classes you don't want off. Quote Link to comment
mmyoung Posted July 5, 2008 Author Share Posted July 5, 2008 Yeah, I do sometimes drag things into other layers or classes, but it's tedious and takes attention I don't want to give it. I was hoping I could just hide/unhide things. It seems like an obvious feature, and it's in the other apps I use, so I wondered how people got around it in VW. Quote Link to comment
mike m oz Posted July 5, 2008 Share Posted July 5, 2008 Reverse the logic. Temporarily group the objects you want to change and then edit the group. Toggle the Show other objects while in groups VW preference off and everything else will disappear. Quote Link to comment
Pat Stanford Posted July 5, 2008 Share Posted July 5, 2008 You can just hide/unhide things. Edit your workspace to put the Custom Visibility command into the Tools menu with the Custom Selection and Custom Modification. It is in the Legacy commands set. You can then use the Custom Visibility command to create scripts to show and hide objects as you like. Two that I find very useful are Show All (to get everything back) and Hide Selected. Pat Quote Link to comment
gmm18 Posted July 5, 2008 Share Posted July 5, 2008 Thanks Pat... How about this one: I would like to have a script that will turn invisible the entire class of a selected object. For Example: Say I click on a chair, I'd like to be able to quickly turn off the Furniture-main class (including the chair itself that is assigned to that class), without having to go find that class in the Navigation Palette to do so. Kind of like how right-clicking an object we have the option to "Activate Class," I want a button to "Make Class Invisible." Quote Link to comment
mike m oz Posted July 5, 2008 Share Posted July 5, 2008 Jonathon Pickup has indicated that he has such a script on his training manual CDs. Quote Link to comment
maarten. Posted July 5, 2008 Share Posted July 5, 2008 Thanks Pat... For Example: Say I click on a chair, I'd like to be able to quickly turn off the Furniture-main class (including the chair itself that is assigned to that class), without having to go find that class in the Navigation Palette to do so. Kind of like how right-clicking an object we have the option to "Activate Class," I want a button to "Make Class Invisible." I posted a little script some time ago that does that. Look here for more info. Quote Link to comment
mmyoung Posted July 7, 2008 Author Share Posted July 7, 2008 Just wanted to thank everyone for the replies. Huge help. ?Michael Young Quote Link to comment
gmm18 Posted July 7, 2008 Share Posted July 7, 2008 Yeah thanks for the script Maarten. Quote Link to comment
laura_m Posted July 22, 2008 Share Posted July 22, 2008 used your script and it works a treat, thanks. Quote Link to comment
