Andrew Mac Posted June 30, 2008 Share Posted June 30, 2008 (edited) When using the space planning tool is there a way to use the "return key" to stack my room name for for better placement in the drawing? Edited June 30, 2008 by Mac B Designs Quote Link to comment
RonMan Posted July 1, 2008 Share Posted July 1, 2008 If there is a way, I surely could not find it. This has rarely been a problem for me, but I can see how it could be. Here is another Space Planning tool problem I found while looking on to this. If you add the REMARK to the space using Set Additional Data, I can't find a way to actually enter the REMARK test. RonMan Quote Link to comment
TBrown Posted July 3, 2008 Share Posted July 3, 2008 Here is one way around the problem. I have experienced it many times myself. Type out the Room Name the way you want it to appear, someplace on screen, then select just the text portion and copy and paste it into the room name portion of the dialogue box. Quote Link to comment
mr. iagea Posted July 9, 2008 Share Posted July 9, 2008 (edited) I'm not sure if I'm understanding your question, but you can edit and move the space name by first selecting the space, then edit the name in the object info panel. also, to move the actual name, use the selection tool and click on the name itself, assuring that it becomes active (the blue square is available). you can then move the name wherever you want in the space. be sure to select just the blue dot on the space name to move it, otherwise you'll move the entire space. hope it helps. charlie Edited July 9, 2008 by mr. iagea Quote Link to comment
