Vectorscript for "Make Guide"?
I'd like to be able to use the "Make Guide" command with the keyboard shortcut "G", but simple keystrokes (w/o a modifier) are only available for tools and not menu items, for whatever strange reason. I thought it might be possible to make a tool script that executes this command and then assign that shortcut to it. Can someone enlighten me what the syntax would be for running that command in VectorScript? Thanks!
Sorry for being no help on a non-modified keystroke for Make Guide but I've been using for years. The forward slash is right above the right command key on macs. I think as important is the unlock command to go with it. A script for an unlocked Make Guides would make sense. I do use for Unlock and for Lock which are directly above the /.
Create a new "Tool" PIO, paste in the following code.
Next, add it to your workspace and set a keyboard shortcut to the tool.
PROCEDURE Set2Guide;
VAR
x, y : REAL;
h : HANDLE;
BEGIN
DSelectAll;
GetPt(x,y);
h := PickObject(x, y);
IF h <> NIL THEN BEGIN
SetSelect(h);
DoMenuTextByName('Guides',1);
DoMenuTextByName('Unlock',0);
END ELSE SysBeep;
END;
Run(Set2Guide);
Using the "DoMenuTextByName" command I've also made a script for selecting all guides (so that I can assign the shortcut option+G to it). Can something be added to the script so that the command is executed immediately, i.e. doesn't require another mouse-click?
Currently, the script looks like this:
PROCEDURE SelectGuides;
BEGIN
DoMenuTextByName('Guides',2);
END;
RUN (SelectGuides);
