SLR Posted June 21, 2008 Share Posted June 21, 2008 I have a question for the designer I'm working with, he's working on 08 (i'm still on 12.5) and he has these purple lines that show up on his drawing beneath all the layers. We checked to see if it was Grid lines, loci lines or page breaks which of course its not any of those things. What are they and how do we turn them off?? Quote Link to comment
islandmon Posted June 21, 2008 Share Posted June 21, 2008 Could be a nefarious unnecessary Working Plane ... Quote Link to comment
sig_eigei Posted June 21, 2008 Share Posted June 21, 2008 check to see if he imported a DWG with 2D loci. Maybe those objects are sending out lines in the X-Y directions. Also make sure that you are in 2D plan mode and not a rotated 3D space as noted above. Quote Link to comment
Ray Libby Posted June 22, 2008 Share Posted June 22, 2008 Posting the file or an image would help to troubleshoot. Quote Link to comment
eamon Posted June 22, 2008 Share Posted June 22, 2008 Hi I have experienced this problem before. It is very frustrating as there is not obvious cause to it. There is a way to get rid of the dashed purple lines. I use a mac. Go to Preferences, then click(de-select) the Snap to Loci option. Hey presto, your lines will disappear! I found this work around trawling the internet on some obscure sites. I am of the assumption this works accross in PC land. I do not know what causes this but have just found a solution. best of luck with it eamon Quote Link to comment
eamon Posted June 22, 2008 Share Posted June 22, 2008 I have only ever been on VW 11.1. I have only seen it on this platform eamon Quote Link to comment
