Split tool doesnt work for extrusions created from polylines
Has anyone noticed the following:
If you create an extrusion from a polyline then try to split the extrusion using the split tool, it doesnt work.
If you go in to the edit mode of the extrusion and convert the polyline to a polygon, you can then exit and split the extrusion with the split tool.
It appears extrusion created from polylines cant be split.
Is it supposed to be like this?
