eegriega Posted June 19, 2008 Share Posted June 19, 2008 hi does anyone know how to import survey data to create a site model/dtm AND retain the original point id codes with the stake objects? i am trying to draw elevations from survey data but all i have is a cloud of stake objects and no way of really knowing what is what and how it all relates to eachother. cheers Quote Link to comment
dspearman Posted July 20, 2008 Share Posted July 20, 2008 Select an objects and look in the Object Info Pallet. Select all of the stakes and from the Object info Pallet change the label to description / elevation. Quote Link to comment
Bryan G. Posted July 22, 2008 Share Posted July 22, 2008 Quite often when we import our data the text needs to be down sized to be able to read the points. Is this what you are referring to? Quote Link to comment
dspearman Posted July 25, 2008 Share Posted July 25, 2008 In that case just select the stake objects and use the Text menu (Text > Size >) to make the adjustment. Quote Link to comment
