carch Posted January 17, 2001 Share Posted January 17, 2001 is there a way to fillet with a zero radius. I'm trying to get to two lines to meet to make a 90 degree conrner. I can not use the extend tool. The extend tool is out of range. thanks ce Quote Link to comment
doug shaffer Posted January 17, 2001 Share Posted January 17, 2001 have you tried the 'join' tool (command-J)? select both lines and go to the TOOL menu, then select 'join'. ------------------ d. s h a f f e r a r c h i t e c t Quote Link to comment
