Embedded Objects not taking on class attributes of container object
Is the following a bug?
I create a polygon (none class)
Then create floor object from polygon
Assign "Floor" class to floor.
All the floor objects fills, pen colours etc are set to "class style"
Change "Floor" class pen attributes to blue and solid line and tick "use at creation"
The outline of my floor looks blue solid line.
I know create a viewport of the design layer containg the floor object.
I select the viewport and do a class override on the "floor" class. Change to red line dashed. click OK.
The floor is unchanged.
I then go back to the floor object, double click on the floor object to get to the edit mode. select the polygon and assign the same class as the floor object ("Floor" class).
I return to the viewport and appears red dashed.
Why does the embedded object not take on the class attributes of the container object in viewports?
