EduardoS
I find a bug
A bug in editing floors.
Make a rectangle, select it and create a floor. Select the floor and in edit mode draw another rectangle overlapping the fist, exit editing mode. Some one has disappeared...
I think this is how it is supposed to be. If you were to combine the two rectangles in to one polygon then I think it would work.
Eduardo, not a bug. A feature. Use it to cut holes in your floor. If instead you are looking to add a part to the floor try using the Add Surface command.
A feature!!! I prefer the way it was!
I was trying to separate the floor in two parts, one with a tile hatch. I always did it to don't have two floors at the same level just for a hatch. Got to do it from the beginning with two polygons to work.
