Worksheet S%#$ the bed
Hi can someone please have a look at this worksheet and tell me why it is doing what it is.
All exterior walls are in a Record Format "Exterior Walls"
The worksheet is broken in to 3 areas (Ground First and Second)
and references the Exterior Wall Record Format for each level.
Hi Andre,
It seems like there is a data corruption in row 14. I would be interested in knowing how this happened. Was the file originally created in a previous version ? Did this happened during file translation.
Any info would be appreciated.
Thanks,
Hugues
NNA
Hi Hugues
Yeah I created the record format and worksheet in another file (same version), then imported into a new file.
The original worksheet only had the "ground floor" and "first floor" info in the databse, then after import I copied the "first floor" cells pasted in a new set of cells and changed the "criteria" from Layer>Mod First to Mod second.
It was some time after this that I noticed the problem.
To fix I deleteed the bottom 15 rows approx and then just re-entered the equations.
Hope that is of some use to you, let me know if you require any further info.
