Polyline tool drawing curved instead of straight
Someone can correct me if I am wrong here, but I believe this is because you are dragging when you are clicking your second point. It lets you make sort of spline like motions if you drag or hold ctrl as going to your second or subsequent point.
Matt
I use the click-drag feature often to draw lighting plans, so I can "spline" my wire lines between light symbols. On the other hand, if you are not intentionally holding down the button while clicking the mouse, I would suspect there might be a bug (or a severe lag between your mouse response and the cpu).If you happen to hold the button down while clicking, your line will become a curve, until you click again.
