Line weights in Door objects
I'm having trouble being able to specify different line weights for separate parts of door objects. My assumption is that if I specify let's say a 0.05 line weight for the swing (under Door Settings > View > Use Part Line Styles) this setting would override the PIO's line weight, whether it's "by class" or otherwise. However, whenever I print or preview the drawing, all of the door parts print the same. Any help? Thanks!
Thanks Ion! You're right - I overrode the line style and weight for the door object (so they weren't "by class"), and the swing showed up as a nice thin line, just as intended. Seems kind of silly though: I just posted another question where I asked how I could make the elements (lines) within symbols take on the attributes of the class the symbol is assigned to. For instance, I want to use thin lines for all door swings, but I want some of the door objects to be in a class for existing doors, with a ligher overall line-weight, and some of them in a class for new doors, with a bolder overall line-weight. Sure seems cumbersome to have to override the line weights for all of the door objects, rather than being able to control them using classes...
