Entasis Posted June 11, 2008 Share Posted June 11, 2008 I want to make a worksheet without borders around some of the cells. When I edit the format of the cells I can get the borders to disappear by selecting "none" in the borders dialog. But when I return to my sheet the worksheet still appears with borders around the cells. Help! Quote Link to comment
Pat Stanford Posted June 11, 2008 Share Posted June 11, 2008 Under the Worksheet pulldown menu go to Preferences and uncheck the Show Grid check box. Then the only thing that will show are the cells that you have put borders around. Pat Quote Link to comment
Entasis Posted June 11, 2008 Author Share Posted June 11, 2008 Ah - yeah that worked. Thanks! Seems like the border around the whole worksheet can't be suppressed, but I can live with that. Quote Link to comment
Gerrit Posted June 11, 2008 Share Posted June 11, 2008 The attributes of a worksheet-on-drawing can be set using the Attributes palette. So, chosing a line width of 0 results in a borderless worksheet. Quote Link to comment
