CS1 Posted May 30, 2008 Share Posted May 30, 2008 When you bring up the Class/Layer Organization Menu, at the top right of the screen there are 2 tick boxes: Details and Visibilities When yuo click Visibilities you have the option to click a class and then tick which viewport it is visible on. This doesnt work for design layer viewports. On the attached file you can see the left column contains a list of classes, the right column is empty because I have no Saved sheets, and the middle column is empty indicating I have no viewports. (I have around 5 viewports all on design layers.) Quote Link to comment
Jeffrey W Ouellette Posted May 30, 2008 Share Posted May 30, 2008 Andre, This is WAD (Working As Designed). The class and layer structures for DLVPs are unique to each DLVP. Since the DLVP may contain internal or externally referenced information and that the graphical attributes can be overriden, made different from the active document class attributes, they are handled on a case-by-case basis. I see no problem with that working method. Quote Link to comment
