DALucy Posted May 28, 2008 Share Posted May 28, 2008 Hi, I have made my objects into materials like glass, but when I got to render it in Renderworks, I can only see the Open GL, with none of the material attributes. Even when I use the Renderworks camera, it still doesn't show properly. I don't think I have turned anything off, so any ideas why this might happen? It has been working previously in other drawings I have done. Thanks in advance! Quote Link to comment
Gerrit Posted May 28, 2008 Share Posted May 28, 2008 Have you checked the Open GL settings and enabled Textures ? Quote Link to comment
DALucy Posted May 28, 2008 Author Share Posted May 28, 2008 Yep, textures enabled. It does render in Open GL fine, just not in Final or Fast quality Renderworks. I now have some objects rendering in glass but not others - why is it selective about what it renders? Thanks for your help Gerrit Quote Link to comment
Gerrit Posted May 28, 2008 Share Posted May 28, 2008 It may depend on the kind of objects at hand. Take a look at the image : extrusions support a texture differently from a column and a floorslab. Also, there is a difference between OpenGL and RW results. Quote Link to comment
