alexwoody Posted May 21, 2008 Share Posted May 21, 2008 was working on some plans this morning.... closed the comp for lunch.... went to open after lunch and the file said that it was created using an older version and it wants to change the name. So you do and then it says that it could be mini cad file or has got corrupt. Wasn't sure what to do. Someone mentioned something about temporary files. But it doesnt look good considering the file says that it contains 0kb!! Pls help!! Quote Link to comment
visard Posted May 21, 2008 Share Posted May 21, 2008 First calm down and take a breath. Exit without saving. Do you have any previously saved versions of the file? Will they open? Give us a little more information on what you have done to this point. Quote Link to comment
alexwoody Posted May 21, 2008 Author Share Posted May 21, 2008 have no previous saves and other files are fine. Just this one is bad. Quote Link to comment
alexwoody Posted May 21, 2008 Author Share Posted May 21, 2008 have calmed down a little....just got so much detailing to do and the football is on! but thanks for your help...if you can. Quote Link to comment
Jonathan Pickup Posted May 21, 2008 Share Posted May 21, 2008 i have a trick that will help, but it won?t help you how... use your VectorWorks preferences to turn on the Autosave. Choose to save a backup of your files, turn off the confirm before saving and keep the last 5 or 10 copies of the file. This gives you a few files to go back to. Quote Link to comment
brudgers Posted May 21, 2008 Share Posted May 21, 2008 Call it overkill. I save the last 24 copies. Disk space is cheap. Quote Link to comment
SER Posted May 22, 2008 Share Posted May 22, 2008 I have just had exactly the same problem, only I've just lost my entire final year university project! Can anyone help recover a corrupt file, autosave was switched to work every 5 min, but I can't find any autosave files. The document is also reading as 0KB. Please please please help, if I can't get this work back, I'll have to resit 2 years! Quote Link to comment
Gytis Posted May 22, 2008 Share Posted May 22, 2008 In VW Prefs>Autosave, what are your settings? Overwrite or backup copy? Then there are options for where it is saved...original location or custom. If you were doing backup, this may help you find a backup file. Quote Link to comment
alexwoody Posted May 23, 2008 Author Share Posted May 23, 2008 am also in final year lost all my final plans!! got a week to rectify. I went to the mac shop and they said if it is reading as zero kb then there is nothing you can do because there is no information at all. The only thing that may work is using diagnostics to try and repair the file but with a file like that it is 99% failure rate. Another option could be if you have temporary files for vectorworks (i didint) it may have saved something before it happened. But i think you may have to redo it sorry for bearer of bad news Quote Link to comment
mclaugh Posted May 23, 2008 Share Posted May 23, 2008 Ok. Again, DEEP BREATH. The data is PROBABLY still there, it's just been decoupled from the file database, so there is a reasonably probability that the file(s) can be recovered. (Alex, if the guys at the alleged mac shop did not recommend a file recover program, they're a bunch of idiots.) Before doing ANYTHING else, go out and buy a boxed copy of Data Rescue II or File Salvage (do NOT download it or you risk overwriting the missing data), and beg, borrow, or steal an external HD to install it on and to copy any recovered files to. In this case, I would recommend Data Rescue II because it comes with an emergency boot CD. Whatever you do, DO NOT install it on the HD that has the corrupt file or you may overwrite part of the missing data. If you are not running from the emergency boot CD, install the program on the external drive, launch it and run a comprehensive deep recover scan. This WILL take several hours, depending on the size of your drive. When it's done, you will be presented with a list of several hundred/thousand files with descriptive names like, "File xxxx", "Picture yyy", "Document zzzz," etc. At which point, you have to go through the list opening up likely candidates until you find the files(s) you're after. (You can skip a lot of files based on file size.) Good luck. Quote Link to comment
