eegriega Posted May 20, 2008 Share Posted May 20, 2008 hello i've created a dtm of a site i've recently surveyed with a leica total station and am having some problems with it. 1 the site has a stream running through it and i have tried to highlight this by creating a polygon and then sending it to the surface, and then render this using open gl. this is partially successful, however once i send the polygon to the surface it goes all weird(??!! thats a technical term...) 2 where do you find symbols/models of trees that can be used on site models? i presume that once you have said symbol/model you can use the send to surface funtion? 3 how can i attach a boudary fence to the outer edge of my site model? i've attached a copy of the offending file with this message any help would be greatly appreciated cheers vectorworks 2008 acer aspire 7520 amd athlon dual core 2gb ram 80 gb hdd windows vista... Quote Link to comment
monkey Posted May 21, 2008 Share Posted May 21, 2008 you can locate trees to use in the vectorworks library, there are plenty of 3d symbols in there, you can access them by selecting add new favourites in your resource browser. i have tried to have a look at your DTM but for some reason its all fuzzy an doesnt behave properly when i open it. Quote Link to comment
eegriega Posted May 21, 2008 Author Share Posted May 21, 2008 hey thanks for that strange that the dtm isn't opening ok, i've just downloaded it and it opened fine with vectorworks 2008... thanks for the advice about the trees and the resource browser. cheers b Quote Link to comment
Bryan G. Posted May 29, 2008 Share Posted May 29, 2008 eegriega, try using the 3d polygon tool in the 3d modeling set, this may help you with a quick stream. As a side note I'm not sure what each point is when I turn on the label reference to list the description they don't tell me what the points are, this could help greatly, or if you have a listing system then Ignore my previous statement. Quote Link to comment
