orangeman Posted May 14, 2008 Share Posted May 14, 2008 Hi, is there a good an working way to import data from VW into Photoshop? I would prefer to only get rasterized lines in photoshop (all white areas should appear empty). I was trying to use the eps export but the result isn't very clean. I also tried a pdf instead but somehow, even if acrobat is showing the correct data, photoshop only imports the data that was on the active VW layer. Is there another way to do it? I would like to do a little bit of color finishing in photoshop... Quote Link to comment
Ray Libby Posted May 14, 2008 Share Posted May 14, 2008 Export image? You can choose photoshop as the format. Quote Link to comment
Jonathan Pickup Posted May 14, 2008 Share Posted May 14, 2008 file > export > export image file.... make sure you set the resolution and the size of the exported image. often people forget to set the size of the image, or the resolution and then they get unhappy about the quality of the image in photoshop Quote Link to comment
IanH Posted May 15, 2008 Share Posted May 15, 2008 Orangeman. Not sure what yo are doing with PDF, but I use it alot and it should import all layers whether visible or not. You may need to change some defaults. It may also be down to the version of photoshop that you have. I have an old version of Photoshop V6 and it behaves differently to my latest Photoshop Elements 6. I need to use the latter when importing from 2008 are there are some oddities. I presume this is simply down the version of PDF that VW is exporting as it may be writing a later version PDF than V6 can handle. If you are colour finishing 3d models, take a look at Piranesi. It is basically a painting application that understands 3d, depths, materials and hence is very quick to use as you can mask areas at a click of a button and apply textures and styles with a pen or as a whole area fill. Check out the gallery to see what people use it for. If you are UK based, you can also buy Piranesi or upgrades for your Adobe apps from me. Quote Link to comment
orangeman Posted May 15, 2008 Author Share Posted May 15, 2008 Hi Ray Libby, yes I can export as an image file but it will result in a flat image (on layers). Also transparent areas will be white. I would prefer a layered output where transparent areas stay transparent (as they do in an eps file). axel Quote Link to comment
orangeman Posted May 15, 2008 Author Share Posted May 15, 2008 (edited) Hi IanH, you are right. I was using CS1 but when switching to CS3 everything works fine! Thanks. Is there a way that all pdf layers are transformed to photoshop layers? Axel Edited May 15, 2008 by orangeman Quote Link to comment
