Thunder Posted December 11, 2000 Share Posted December 11, 2000 I am looking for an Animator Program! I want one that is Mac compatible and easy to use with VW 8.5.2 and if at all possible not too expensive. But overall the bottom line is something highly recommended by Vector Works that does not require a complicated export/import procedure. All informaton is appreciated!! Thanks Quote Link to comment
Guest Posted December 12, 2000 Share Posted December 12, 2000 Thunder: Could you please be more specific as to what type of animation you are trying to create? Does the "Create Animation" menu item not provide the features you are looking for, and if not, what features are you looking for? ------------------ Brian O Nemetschek North America Technical Support Specialist Quote Link to comment
Thunder Posted December 13, 2000 Author Share Posted December 13, 2000 quote: Originally posted by Thunder: I am looking for an Animator Program! I want one that is Mac compatible and easy to use with VW 8.5.2 and if at all possible not too expensive. But overall the bottom line is something highly recommended by Vector Works that does not require a complicated export/import procedure. All informaton is appreciated!! Thanks From what I have gathered from the VW program it is some what limited in the fact that other then the camera you cannot have any other moving parts such as a tool performing a task or a door opening in front of the camera as it moves through the house. Specifically we want a progam that would let us animate our repair procedures, Example: A panel moving away from the unit A tool performing a task, the part being removed, the replacement part being put into place, the unit bieng reassembled. Ultimately we would also use it to animate or production procedures. Quote Link to comment
