Perspective in Viewport Acting Wierd
I have attached an image of whats going on.
All of a sudden my viewport of a perspective lost a coner of the image. Its almost like a crop has been applied, however when I change the foreground render from none to hidden line I can still see the outline of the info that is not showing up in foreground render none.
I have tried rotating the view in the crop mode and it seems as thou the problem is reletive to the view no the model. If that makes sense.
Edited by CS1
The image with the problem is rendered as "openGL", I have just found that if I change to "Final Quality RendorWorks" the image appears fine but as soon as I go back to "openGL" the problem reoccurs.
Whats going on?
Edited by CS1
