COMJAX Posted May 1, 2008 Share Posted May 1, 2008 For some reason VW's twisted sense of humor has decided to rear its' ugly head and tick me off today. Why when I do any type of rendering why does my bolt look like this? It's ONLY doing it in this drawing. If I Ctrl+C it out and paste it into a new drawing it's fine. Quote Link to comment
michaelk Posted May 1, 2008 Share Posted May 1, 2008 Does the bolt have a texture? MK Quote Link to comment
COMJAX Posted May 1, 2008 Author Share Posted May 1, 2008 Nope. Not attached to it nor the class. Quote Link to comment
COMJAX Posted May 1, 2008 Author Share Posted May 1, 2008 And it not just this bolt. Any new hardware I make up using the Fastener Tool in MD I get the same results. Quote Link to comment
COMJAX Posted May 1, 2008 Author Share Posted May 1, 2008 Leaving work now, I'll check back in the morning. Quote Link to comment
ionw Posted May 1, 2008 Share Posted May 1, 2008 If I was to take a guess, the bolt has a none fill. Quote Link to comment
COMJAX Posted May 2, 2008 Author Share Posted May 2, 2008 If I was to take a guess, the bolt has a none fill. Nope, it's got fill. Tried by class and by selecting it. The only way I've found around it is to convert it to a group. Quote Link to comment
Tom G. Posted May 2, 2008 Share Posted May 2, 2008 I sometimes find that my fill choice color affects whether or not my object will accept a texture. White fill occasionally will block my texture from taking hold. Try giving your object various other fill colors while checking the object in the Render pane of the Object Info palette, under Mapping, to see if the texture takes. It may be that one object within the group shows this behavior and thus blocks correct rendering of others? I have reported this behavior as a bug. It exists from V. 2008 back through V. 12.0. Quote Link to comment
COMJAX Posted May 5, 2008 Author Share Posted May 5, 2008 I sometimes find that my fill choice color affects whether or not my object will accept a texture. The thing is it's not "my object." It's a bolt I placed in the drawing using the "Fastener Tool" It's just in this drawing that I've encountered this. Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted May 12, 2008 Vectorworks, Inc Employee Share Posted May 12, 2008 If you paste into a new document does the bolt still render the same? If you are still unable to resolve send the file to tech@nemetschek.net Quote Link to comment
