Guest Posted November 30, 2000 Share Posted November 30, 2000 Kpayson, Try the following for possible solutions. 1) Increase Virtual Memory to assist with printing (may take a large amount depending on complexity of the drawing); 2) If using RenderWorks, try using the Bitmap Tool to save memory when printing (will not have to render again); 3) Check for new drivers for the printer; 4) Turn off the "Retain Rendering Model" under the 3D tab in your VectorWorks Preferences (if you retain rendering models you use up memory); 5) Be certain all other programs are closed; 6) Allow at least 100 mb of free hard disk space for spooling. ------------------ Brian O Nemetschek North America Technical Support Specialist Quote Link to comment
kpayson Posted December 1, 2000 Author Share Posted December 1, 2000 I am running MacOS 9.1 with an Epson 1520 printer. I also had this problem on 9.0.4 - I run a print and a seemingly random collection of lines from my drawing will print out. (from various layers) - then I have to quit and restart VW to get the right print to come out. Any thoughts? this is taking up too much time and wasting a lot of paper. kpayson@earthlink.net Quote Link to comment
