lucylou
Walls disappeared in 3d view
Hi. Ive just noticed one of my walls has dissappeared when i look at it in 3d view. its there in plan and i can select it but in section VP and 3D view, open GL its missing! seems like a bug. anyone else have problems like this? I've found previously to just delete it and do it again, however I do worry that there could be an underlying issue??
Do you have a height assigned to that wall and/or have you "Linked wall height to Layer delta Z" in the OIP?
yes height was assigned to it. it was weird as you could select it in 3d view and it looked like a 3d wall (apx 2.2m high) seems like a bug of some sort, but don't know where it came from!
Is the wall filled? If it isn't, you will get outlines in 3D instead.
Is the wall assigned to a filled and textured class?
Had you used Fit Walls To Roof on it? I had a problem recently where a lower lean-to roof just overlapped a wall by a few mm, so the wall went to that lower roof height instead of the higher roof above as I intended, resulting in a hole in the side of the building.
I have just had this happen to me again... it must be some sort of bug because Don is right, if you restart VW it re-appears. A real pain to have to keep closing it down and re-opening again though. Any solutions in SP3??? not updated to it yet.
I have an idea, maybe NNA should have a focus group of architectural users and it can be pointed out that anyone using vw architect needs their walls to show up consistently.
lucylou,
we've noticed many of the same issues occur when objects are grouped in a model. if the class of the group or objects within the group are turned off, it may result in visibility issues. these visibility problems don't typically show up in top/plan or wireframe, but often do in openGL or other rendering methods.
one thing you can try as a test is to take a copy of your file, and ungroup everything in your model (assuming you have groups), turn on all your classes, and then take a look at a 3d rendered view.
we have a post which may relate to your issue here:
http://techboard.nemetschek.net/ubbthreads/ubbthreads.php?ubb=showflat&Main=22956&Number=107641#Post107641
hope that helps,
j
this same problem has happened to me about three times in the past hour or so! i am on a new computer, so have recenetly re-loaded VW and other programmes.
once the wall had disappeared, i re-drew it and updated the VP and it was there, then i had to join my new walll into an existing wall and as soon as i updated it, it disappeared for the 3rd time! please please please can someone sort this!!! soooooooooo frustrating!
oh, forgot to add, that after re-reading these posts, i shut VW down and reopened and it did re-appear, but im not planning on doing that everytime, especially when im working on up to 3 files at once, so have to keep closing them all down and re-opening them again! efficient working? i think not!
Do the walls show as a single red line at z=0 when in a 3d view, by chance? I've had a inserted plugin do that to me, while the wall appears fine in Top/Plan view.
This is the second time I have had walls disappear in 3D views.
Here are some screenshots.
1). Wire frame view, note the walls are outlined:
2). OpenGL rendering, NO WALLS!:
3). Same view, but after copy/pasting this into a brand new file:
I have attached a sample file. Note that it is an educational file, so do not copy/paste anything from this file into one of your project files. It will put
a watermark on it. You will not have a problem otherwise.
Any help will be greatly appreciated. The solution of copy/pasting everything into
a new file is not really a workable option. I have too many viewports and sheet layers that would need to be re-built...Many, many hours of work. And then what
if it happens again?
Thanks Wes and anyone for taking on this challenge. I have quit and restarted both
VW and my computer and it still is a problem.
Thanks
I just downloaded the file and it opens and renders here fine. I get the same image as your third image above, but the little yellow car is missing ;-)
Have you checked your OpenGL options in the View:Render menu? Could they have gotten set to some odd setting?
I can make a view like your missing walls above if I turn off the Walls-Interior and Walls-Exterior classes. Are you possibly using a Saved view or sheet layer that has the wrong class visibilities?
Thanks Pat.
No, it is not a class issue, all classes turned on.
Open GL options set on Low and Use Textures.
And it is not just OpenGL, it is all rendering modes.
It is file specific. If I copy/paste to a new file it is fine.
In order to get the sample file small enough I just
deleted a couple dozen design and sheet layers.
What gets me confused is that Lucylou is reporting VW2008, I am on 09.
. I can't figure this out. I am in a world of hurt.
Edited by gmm18
Several possibilities:
1. It could be Ed version specific, but I doubt that. I am running an E series serial number which it like the Ed version but without the watermarks.
2. It could be SP2 specific. I had problems with the SP2 install and had to reofrmat and revert to SP1 and have not tried the upgrade again yet.
3. It could be file specific. How about using YouSendIt or Pando so we could get the whole file rather than the edited version. That would also make it easier for NNA Tech support to download and look at the file. My email will take up to a 40Meg file, so you could email it directly to me at the address in my signature.
4. I know it seems to be file specific, but have you tried resetting your preferences? If that did not work, what about deleting the prefs and reentering your serial number? What about reinstalling VW?
Thanks for the brainstorm.
I tried resetting VW Preferences, no dice.
Also a "purge unused objects"
The file is about 100 Mb's...
I might try going back to SP1
Edited by gmm18
No joy here either...I downloaded the file and can create/view the problem but have no solution.
I'll submit a bug report.
Ding, ding, ding...we have a winner! In the file I downloaded, if I move the walls and floor back near 0-0 all seems to be well
Thanks Ray
Wow. Great catch, Ray.
It's interesting that moving the objects closer to the center makes it render properly, but reseting the origin closer to the objects doesn't.
If you move it in 500' increments, it first starts to render correctly at about 700',-1400'.
Weird, weird, weird.
michaelk
