Referencing layers with viewports. Crash!
paulg
Hello
I have a file ( A) with mutiple layers, It also has layers referenced from file (B). I have created viewports of these referenced layers from B on the layers in A.
Now, When i try reference file A into a new file it tells me the following
" A viewport has been removed from the referenced layer "SEC 05", as these are not supported here."
This would be fine if it did only remove the viewport but alas Vectorworks crashes.
I don't really want to have to delete the viewports in the layers as i still need them.
If it helps, the report generated for apple has this in it...
Exception: EXC_BAD_ACCESS (0x0001)
Codes: KERN_PROTECTION_FAILURE (0x0002) at 0x0000000c
Anyone come across this or have a cure.
Thanks
Paul
Working on a Imac G5
Mac os 10.4.11
Vectorworks 2008 13.0.1
Paul, did you attach the crash log to the bug report you submitted? If not please, send it to me (tfapohunda@gmail.com).
Also, What version of VW are you using?
You must be using the old style. If you need the Viewports, you will have to use DLVPs as your referencing system.
Open the Organization dialog
Switch to the Reference Tab
Click 'Settings...'
Under 'Use this method to reference VW files', choose 'Design Layer Viewports'
  • 2 weeks later...
