D Wood Posted April 22, 2008 Share Posted April 22, 2008 I want to have a 180? curved glass block wall around a stair landing. Neither WinDoor or the WindowWall(curved) tool can do it, or at least I couldn't get either to work. Has anybody drawn such a wall/window, and how did you do it? Quote Link to comment
Jeffrey W Ouellette Posted April 22, 2008 Share Posted April 22, 2008 David, Use the Wall tool. Just create a class with left and right textures of glass block. For a curved wall, you could create two textures - one for the "exterior" side with a wider block pattern and one for the "interior" side with a narrower block pattern. Quote Link to comment
D Wood Posted April 22, 2008 Author Share Posted April 22, 2008 That's a good start, thank you. Where might I find a glass block texture? The glass/metals/plastics library doesn't have any - is there another source? An ordinary glass texture of course looks great, but I need the pattern and part translucency of blocks. Quote Link to comment
Benson Shaw Posted April 22, 2008 Share Posted April 22, 2008 Or draw a block with glass texture, symbolize it and build your wall with dupes of the symbol. Fool around with the transparency and bump options to make the texture look like the style of block in your spec. -B Quote Link to comment
maarten. Posted April 22, 2008 Share Posted April 22, 2008 Not sure if it's included in the US version, but there's a tool to make such walls: Quote Link to comment
Dieter @ DWorks Posted April 22, 2008 Share Posted April 22, 2008 that's the WindowWall(curved) tool Quote Link to comment
Jeffrey W Ouellette Posted April 22, 2008 Share Posted April 22, 2008 Try this. Don't ask where I got it, I don't remember. Over the last 15 years I've built up quite a collection of misc. images to use for rendering. Quote Link to comment
CipesDesign Posted April 22, 2008 Share Posted April 22, 2008 Thanks Jeff ;-) I'll add it my collection (and probably forget where it came from). Quote Link to comment
D Wood Posted April 22, 2008 Author Share Posted April 22, 2008 Maarten It looks like the WindowWall(curved) tool, although it's a little strange being in the Interior menu. Maybe it got upgraded for v2008, because in v12.5 the number of transoms is limited to 3. Looks better, but not exactly like glass blocks. Quote Link to comment
mike m oz Posted April 23, 2008 Share Posted April 23, 2008 Maarten it must be a another one of your local customisation tools because it is not possible to produce anything like what your image shows with the curved window wall tool. It looks very nice. Like the curved window wall tool should be. Able to have: - Equally spaced vertical mullions. - Equally spaced horizontal members. - Glass faceting that matches the framing. - Both one and two sheets of glass (one on each face). We wish... Quote Link to comment
Dieter @ DWorks Posted April 23, 2008 Share Posted April 23, 2008 (edited) The tool creates a group from a 2D shape where you can set width, height and spacing for the glass blocks and how many rows. Not too difficult to program. Edited April 23, 2008 by DWorks Quote Link to comment
mike m oz Posted April 24, 2008 Share Posted April 24, 2008 Not too difficult to program. Maybe for you but for those of us who are mere mortals... Perhaps you can be generous and post a sample script of how this can be done over in the VectorWorks Resource Share - VECTORSCRIPT forum. Quote Link to comment
Kevin Posted April 24, 2008 Share Posted April 24, 2008 I had to do the same kind of wall. I made 3d blocks, gave them a glass texture and built the wall using the Duplicate Array tool. It worked fine, however it takes FOREVER to render in FQ. All of those transparent glass faces creates a lot of computing. I did not even try to address the grout. Quote Link to comment
islandmon Posted April 25, 2008 Share Posted April 25, 2008 Must make a Symbol of the Block including the grout edges prior to DupArray. This will greatly reduce the rendering times. Quote Link to comment
