EGD Posted April 21, 2008 Share Posted April 21, 2008 HELP!!!! I have created several plants using the symbols that came with 2008, First problem, if i render open gl they all disappear, that does not help me if my deck has textures, house has textures, etc and then I want to print a rendered plan view, and all my plants disappear. Why? 2) investigating this more it also seems there is an inevitable connection to the "none" class, even though all the pieces are on other classes, like the , canopy, outline, tag, fill classes, but when i view these in top/plan they will disappear if the none class is shut off. The tag and cross still appear, but the plant symbol is gone. WHY? Quote Link to comment
dspearman Posted April 22, 2008 Share Posted April 22, 2008 Is the placed plant object in the 'none' class? Quote Link to comment
EGD Posted April 24, 2008 Author Share Posted April 24, 2008 No, all of our plants are placed on our class " plants new" Each component of the individual plants are in the specified class of, outline, color fill, tag, and canopy. All of which were part of the original plant symbol we defined. we are also having problems with turning off the color fill class, and our plant outline then disappears even though it is in a different class, but that seems to be specific to one symbol( a vectorworks predefined plant symbol), so i think that is a bad symbol to start with. Quote Link to comment
IanH Posted April 24, 2008 Share Posted April 24, 2008 (edited) What graphics card and drivers are you using? I've seen instances similar to this when half a tree symbol disappears - I have always though of this as probably being a graphics card/driver issue. First problem, if i render open gl they all disappear, that does not help me if my deck has textures, house has textures, etc and then I want to print a rendered plan view, and all my plants disappear. Why? Im not sure if I understand your first problem correctly but if you are in "top/plan" view then you use the 2D part of the plant symbol, if you go to "top" view, or any other non plan view, then the 3D part of the symbol is used. By default, the 3D part is not set up, which may be why your plants are disappearing when you go to OpenGL mode because this will switch from Top/Plan to Top view. To see plants from above, ie from Top, you need to add a 3D component to the plant symbol. [edit] Oddly, I have just opened one of my documents and have noticed some trees with and outline that appears in both Top/Plan and Top mode. But another tree, in Top mode, the outline just disappeared. Opening the two plant symbols, and viewing the symbol in top view, the one that remains has indeed got a 3D symbol, but I can't remember where I got it from. I don't think that I intentially put it in there although I was experimenting with the symbol so could have done enything! The odd thing is that I can't edit the 3D symbol. [/edit] Edited April 24, 2008 by IanH Quote Link to comment
PLC-Landscape Posted May 13, 2008 Share Posted May 13, 2008 EDG I cannot help with your problem, but I did go on your website, and I'd like to say that your renderings are great! Are those drawn freehand and scanned in, of done with software? - I love the natural hand rendered look. Very nice. Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted May 19, 2008 Vectorworks, Inc Employee Share Posted May 19, 2008 Daniel, Please send your problematic file to tech@nemetschek.net for better assistance with this problem. Quote Link to comment
boundnorth Posted May 19, 2008 Share Posted May 19, 2008 I'm having a similar problem with plants disappearing in Top Plan view. I place the plant, usually have to go into 2D graphics to place the plant graphics on top of the plant loci, and then when I enable 2D rendering, everything about the plant graphic disappears except the crosses marking the center points and the line connecting multiples of the same plant. Very frustrating and time consuming. Plants are in Plants Proposed or Plants Existing classes. Quote Link to comment
