daryl
Plant count
Now that I've figured out that the plant list shipped with VW2008 needs to be edited to record the botanical names (seems like an obvious fix for Nem.), the quantity column seems screwed up. Unless the plants of a particular variety are all in the same group, the list won't tally them. I just get a dashed line in the quantity column.
Is it just me??
it depends on what you are using to sum the plants. If you sum them but the ID number you will get all the same id?s together, if you sum by the Latin name, you might get dashes in the id column
Ok, but why does my group of 4 Zelkovas show up on the plant list as '4' if they are in the same group but only as '1' if they are individuals?
perplexed.
I am also getting the dashes. This is on a file converted from 12.5, with plants imported to VW2008. I just watched a 'Tech Tip' video describing how to import 12.5 plant symbols, and I think I may have checked the wrong button when it asked about importing the record format too!
Daryl, are you using 12.5 symbols?
Just trying to diagnose my problem! It is not a sum ID v. sum Latin name problem, not for me anyway.
--alchemilla
VW2008
Windows XP
Dell Inspiron 6400
I am havign this same problem. I imported a bunch of files to update from 12.5 and now if I recalculate my sums I get 0 plants, where I ought ot have 47, or what have you.
Please help!!!!
To resolve the quantity problem open a blank document. Place one of the default 2008 plants on the drawing. Then go to your file and in the resource browser import the plant you placed in the new document into the your current file. You should get a message the the record format already exist. Choose to replace. When the plant list is recalculated the quantity should show.
