CS1 Posted April 13, 2008 Share Posted April 13, 2008 Does anyone have this problem> If I rotate my plan then select two objects and use the align distribute tool, the OIP says two objects selected but the objects on screen disappear and their highlighted selection box disappears. I have checked that I only have two objects selected (two rectangles) with no other objects on screen that may through it off. If I reset the plan to horizontal and perfrom the same task it works fine. Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted April 14, 2008 Vectorworks, Inc Employee Share Posted April 14, 2008 Hi, I am trying to duplicate your issue but am unable to do so. Are you using the Align/Distribute command in the Modify menu, or are you using the Align/Distribute Items tool from the Spotlight tool set? Quote Link to comment
CS1 Posted April 14, 2008 Author Share Posted April 14, 2008 From the modify menu Quote Link to comment
