Jeff24 0 Posted April 8, 2008 Hi everyone, I've searched the forum, and haven't really been able to find a simple answer to what I'm looking for. I'm a fairly new VW user, and the same goes for Landmark. I'm creating simple site plans for my company, and I like to insert simple generic 2D trees to 'dress up' the site plans a little. However, upon insertion, the trees are just simply white, and the same goes for when I print the site plan. Is there an easy way to colour them in green, or some sort of hatching to give them more colour? I know how in the edit options of the plant, when you click the render the tab, it shows the tree as coloured along with the shadow placement for the tree. Hopefully my question is clear. Any help is greatly appreciated. Thank you very much! Quote Share this post Link to post
RHA 0 Posted April 8, 2008 not sure if this is the problem, but check to see if under File/Document Settings the black and white box is checked. Quote Share this post Link to post
Jeff24 0 Posted April 8, 2008 Thank you for your reply, but that is not the issue. I have coloured hatching for the grass, pavement, etc. It's just the trees I insert have no colour to them. They are just white. Quote Share this post Link to post
CipesDesign 149 Posted April 8, 2008 If the trees are symbols, you can edit them and change the color to whatever you like. Quote Share this post Link to post
Jeff24 0 Posted April 8, 2008 Cipes, how can I do that? When I go to edit the tree, it asks me what to edit: 2D, 3D, plus two more options. None of them seem to show anything. I assume they are symbols that I am inserting. I point to this: Place Plant ---> Preferences ---> Edit Definitions ---> Render Tab ---> check box of Plant Shadows in Plan View - The tree shown here is coloured with a shadow. Is that what is supposed to show up? This might seem very simple, but I am very perplexed as to why I can't figure out how to insert a coloured tree, OR, colour the trees that I have inserted. Quote Share this post Link to post
Jonathan Pickup 285 Posted April 8, 2008 do you have mass overlapping plants? Quote Share this post Link to post
Jeff24 0 Posted April 8, 2008 (edited) I don't think so, I just place them sporadically around the site, just to give it a better presentation quality, etc. Should I check the overlapping box? Edit: I did that, same result. No coloured trees. Edited April 8, 2008 by Jeff24 Quote Share this post Link to post
CipesDesign 149 Posted April 8, 2008 Jeff, When you click "Edit 2d" and get nothing, try using the "fit to objects" button at the top of the VW's window. This ought to put the object (Plant Symbol) in the center of your screen. Once you locate the thing, simply select the polygon(s) that were used to create it, make sure they are set to "Solid" in the Attributes Palette, and then change the color to whatever you like. Here is a quick example that I just did: Quote Share this post Link to post
Jeff24 0 Posted April 8, 2008 Jiminy Christmas, it worked! Selecting the Polygons within the plant/tree was a little tricky, as some wouldn't change at all, but when I finally grabbed one, I changed it's solid fill to green, and voila, the plants/trees in my site plan are now green. Good enough! Thank you, Cipes. I appreciate your help. Quote Share this post Link to post
dspearman 1 Posted April 8, 2008 If mass overlapping plants (in the render tab of the plant definition) is checked you will get exactly the result you are getting now. Try UNCHECKING it and see if the problem goes away. Also ensure all classes are turned on. If the colour fill is part of an object (still in the plant object) that has a class, and this has its visibility turned off or to grey, you will get the result you have now. If turning all classes on solves the problem you may have to experiment a little to find out what class is the one you need to turn on. If you are using plants from the Plant Object file that comes with Landmark 2008 the class would be 'Plants-Component-Canopy' or "Plants-Component-Colour Fill' Quote Share this post Link to post
Thom 14 Posted April 8, 2008 Jeff Not to toot Jonathan Pickup's horn, but his manuals are the best going. Written for us lay men. Quote Share this post Link to post
Jeff24 0 Posted April 9, 2008 Thank you everyone for your comments/answers. I really appreciate it. Quote Share this post Link to post
Bex000 0 Posted May 23, 2019 Question.. Can you have colour on mass planted trees, when the original symbol came from the Black and White library? Thanks BEX Quote Share this post Link to post
