wybe
objets dissapear after importing DWG
After importing a DWG some objects seem unselectable. I checked layers and classes options. When I than zoom out the objects dissapear. When zooming in again they are still gone. Does this has to do anything with the classes? And is it wise to tick off the box "DXF layers to classes" when importing?
Two or three times now I've run into the problem you're having and it turned out that an entire layer of the DXF drawing had been made into a symbol. Using "Convert to Group" and then "Ungroup" solved the problem. I don't know enough about AutoCAD to know how this happens, though, so don't know if it will help in your situation or not.
Barb Nelson
RLK HYdro
[This message has been edited by RLKHydro (edited 11-14-2000).]
