Daryl Wood Posted April 4, 2008 Share Posted April 4, 2008 How do it get VW to recognize the "Room Finish Library.txt" file in a space object assign room finishes dialog box? I want to set room finishes but they are not available on the assign room finishes dialog box's drop down lists. It's like the contents of the "Room Finish Library.txt" file is not read into VW. Regards, Daryl Quote Link to comment
Ramon PG Posted April 6, 2008 Share Posted April 6, 2008 Daryl, Check the following to see if we have a common problem. http://techboard.vectorworks.net/ubbthreads/ubbthreads.php?ubb=showflat&Number=100949&page=1#Post100949 Quote Link to comment
Daryl Wood Posted April 8, 2008 Author Share Posted April 8, 2008 Thanks Ramon for the work around. I moved the preferences folder out of the plug-ins location and was able to get it to work. Go figure. Thanks again, Daryl Wood Quote Link to comment
