Importing a dwg file using VW12.5 creates an issue with scaling since the default file import uses inches as the chosen import despite the fact that the file itself may have been set up in metric format.
It is important therefore when importing a dwg file prepared in decimal format to custom select the import and select millimetres or metres as the import option.
I haven't yet found a way of changing the default and would be grateful if anyone could advise me if they have succeeded in changing this.
GD-DO
0 answers to this question
