Jonathan L Posted April 4, 2008 Share Posted April 4, 2008 I have a VW 2008 file that I can't render the viewport of a stair that I have in the design layer. All the options are available in the design layer. In the viewport only a few options are available - sketch, hidden line etc. and none of them work. The image remains a wire frame. Quote Link to comment
Guest Posted April 4, 2008 Share Posted April 4, 2008 Once you choose the render style for the Viewport in the Obj Info Palette, do you click on the "Update" button at the top of the Obj Info Palette? When a viewport has the red and white candy stripe around it, the viewport is out of date, including rendering. Since viewports can take longer to render than design layers, the option to update (or execute a render selection) a viewport is managed through the Update button in the Obj Info Palette. Quote Link to comment
Pat Stanford Posted April 4, 2008 Share Posted April 4, 2008 The other rendering options are found in the Background Render pull down. Background Render is where you want to start. If you then want a line render over the top of your solid render, use the Foreground Render. Pat Quote Link to comment
Jonathan L Posted April 7, 2008 Author Share Posted April 7, 2008 Thanks Katie and Pat. That has sorted it. Quote Link to comment
