Chris Wailes Posted April 3, 2008 Share Posted April 3, 2008 Why is it that when I select my walls and tell VW to do a "Wall Framer" it asks me to do a new Mod layer? I set up templates that already have these design layers and corresponding sheet layers added. Should I delete my framing layers in my templates and then have it create them when I do the framing plan? What is the best procedure for this? Quote Link to comment
Guest Wes Gardner Posted April 4, 2008 Share Posted April 4, 2008 You're probably correct, let VW create them for you... Quote Link to comment
Tom G. Posted April 7, 2008 Share Posted April 7, 2008 Are you sure you read that correctly? As a test I created framed walls on one of my projects. I see an input box in which I can place any text (limited to 8 letters) to describe the layer for the framing-- I was not limited in choosing a Mod layer. I always use terms that are relevant to my drawing process--which is constantly changing and growing--so I don't let VW name layers or (as few as possible) classes for me. Quote Link to comment
