Moving objects in sectional view?
Im pretty sure in archicad you could cut a section and then move objects in that view, for example in a section view select the FLOOR and move up 100mm or so.
In VW2008 how do I do that.
I know if I create a SECTIONAL VIEWPORT and then go in to the EDIT DESIGN LAYER mode it takes me back to TOP/PLAN view.
And if I cut a 2D section that just explodes it to line.
What am I missing?
Section Viewports are snapshot views of the model information which will update when you select to. You cannot make changes to any of the Design Layer information in them - all changes have to be made on the Design Layers.
To temporarily hide background objects in a Section Viewport change the Depth Range on the Extent tab under Advanced Properties
