marqro2 Posted November 7, 2000 Share Posted November 7, 2000 Hi I was wondering if and where I may able to get the update TO 8.5.1 online anywhere. I upgraded the 8.0.1 version I purchased a while ago to 8.5. Now I know that the most current version is 8.5.2, and the installer will only upgrade from 8.5.1. So is there anyplace I can get this upgrade? Thanks in advance. Quote Link to comment
Guest Posted November 7, 2000 Share Posted November 7, 2000 Unless my memory is playing tricks on me, the version you've got most probably is 8.5.1. The so-called "8.5 update" CD that you received actually contains 8.5.1. Caleb Strockbine caleb@nemetschek.net [This message has been edited by Caleb Strockbine (edited 11-07-2000).] Quote Link to comment
PeterT Posted November 7, 2000 Share Posted November 7, 2000 Originally posted by Caleb Strockbine: The so-called "8.5 update" CD that you received actually contains 8.5.1. Caleb, The disk we received does contain 8.5.1, but perhaps Marqro2 never received his disk, or lost it, or destroyed it, etc. I think the point here is that there is no way to upgrade from 8.0, 8.0.1, or 8.5.0 to 8.5.2 via downloads from the web site since 8.5.1 is not posted on the site. Quote Link to comment
Guest Posted November 8, 2000 Share Posted November 8, 2000 Peter, You are correct. You must have 8.5.1 to upgrade to 8.5.2 from the website. The 8.5.2 disc is a full version and does not require 8.5.1 to install. Furthermore, if you have one 8.5.1 cd, you can use that on multiple installations as the serial numbers are what seperate the licenses. A valid license works on any disc. Please contact your distributor to receive a copy of the disc if you so desire. You will need confirmation of your registered serial number. ------------------ Brian O Nemetschek North America Technical Support Specialist Quote Link to comment
