Tobias Posted March 26, 2008 Share Posted March 26, 2008 If I crop a viewport that contains annotations (specifically text), the text blocks outside of the crop remain visible, they are not cropped out. Is that the expected behavior? Quote Link to comment
Pat Stanford Posted March 26, 2008 Share Posted March 26, 2008 Yes, expected behavior. The crop hides things on the design layer outside the crop object. You may want things like notes to be able to extend beyond the crop object. If you want things hidden by the crop, then put them on the design layer and use classes to control the visibility in other sheets or views. Pat Quote Link to comment
Ray Libby Posted March 26, 2008 Share Posted March 26, 2008 Far from a bug, it is a feature for me. Quote Link to comment
gmm18 Posted March 31, 2008 Share Posted March 31, 2008 But a toggle button option to "crop annotations" along with design layer info would be useful at times. I summited this as a wish not long ago. An example of when it would be useful is if you have just finished annotating a Section VP with framing members, insulation, and other details, then you want to duplicate that VP, bump up the scale, and crop it so you can make a custom enlarged detail. In this case being able to click the option to "crop annotations" would be very useful. In the mean time you have to go in and delete the extraneous annotations, but there are still some objects that need to be covered up with a white-fill rectangle in order to "crop" part of them out of view. Quote Link to comment
Tobias Posted March 31, 2008 Author Share Posted March 31, 2008 This is how I ran into it. I duplicated an exist VP, then cropped and enlarged for kitchen detail, and ended up with room names outside of the VP. Not a big deal to delete, I can see where at times it would be an asset as well. The toggle button is a good idea. Quote Link to comment
