mpkeane Posted March 25, 2008 Share Posted March 25, 2008 I am working on a Mac PowerBook, using OS 10.4.11, with VW Designer (Educational Version) 12.5.3 I made a custom hatch for a decking pattern. I applied it to an oval shape I created but now I need to rotate the hatch within the shape so that it aligns to the angle of the oval. Is there a way to rotate a hatch within a shape after it has been applied to a shape? Marc Quote Link to comment
bonus Posted March 25, 2008 Share Posted March 25, 2008 I'm not sure it's impossible but I think so. Maybe you'll get a better reply.....? Meanwhile create a duplicate of the hatch and edit it to a convenient angle. Quote Link to comment
Pat Stanford Posted March 25, 2008 Share Posted March 25, 2008 Short answer - No. Long answer - There are two kinds of hatched in VW. Associative Hatches are applied through the attributes palette. The origin and rotation can not be controlled for an individual object. You would have to go through and edit the hatch. Non associative hatches are applied through the Hatch Menu command. This actually creates a group of lines. You can control the origin and rotation on creation, but not after creation. But you can easily delete the hatch group and recreate it if you need to change the area or the rotation or origin. Pat Quote Link to comment
billtheia Posted March 25, 2008 Share Posted March 25, 2008 If hatch was applied with attributes palette (associative hatch,) use hatch editor to change angle of hatch pattern (right click on hatch in Resource Browser and select Edit.) This will, however, change the rotation for all applications of that pattern. If hatch was applied using Modify>Hatch (non-associative,) you can rotate the hatch but you'll have to do a bunch of trimming to make it meet your oval. You can also delete the hatch, edit the pattern to change rotation, and re-apply the hatch. OR you can delete the existing hatch, rotate the oval to 0 degrees, apply hatch using Modify>Hatch, and then rotate the oval back to your desired angle. Dear NNA, please make it easier to use hatching. Editing using the hatch editor is NOT user friendly. Inability to easily rotate and change the origin of associative hatch is a PAIN. Quote Link to comment
bonus Posted March 25, 2008 Share Posted March 25, 2008 Dear NNA, please make it easier to use hatching. Editing using the hatch editor is NOT user friendly. Inability to easily rotate and change the origin of associative hatch is a PAIN. I do agree! Quote Link to comment
go2greece Posted March 25, 2008 Share Posted March 25, 2008 create a symbol from the hatch than you can rotate peter Quote Link to comment
mpkeane Posted March 25, 2008 Author Share Posted March 25, 2008 Bill Thank you. The idea of applying the hatch through Modify>Hatch and then rotating worked like a charm. Thanks for the tip. Marc Quote Link to comment
eas Posted March 25, 2008 Share Posted March 25, 2008 Yes, but modify>hatch is a group not a hatch and will gunk up your drawings eventually. So NNA please help with better hatches! Quote Link to comment
Dieter @ DWorks Posted March 25, 2008 Share Posted March 25, 2008 (edited) It's scriptable: Take a look at this: Look at the four corners of the drawing, it's the same hatch! http://www.dworks.be/Producten/PIOs/DPoly.html It's doable, so maybe NNA should put this into VW? Edited March 25, 2008 by DWorks Quote Link to comment
dspearman Posted March 25, 2008 Share Posted March 25, 2008 Since you have designer look at Landmark's Hardscape tool. Quote Link to comment
Pox Posted February 6, 2009 Share Posted February 6, 2009 Hi, this is the right link. The application cost 15 ? http://www.dworks.be/Products/PIOs/DPoly.html Quote Link to comment
