Brooke Posted March 21, 2008 Share Posted March 21, 2008 On an elevation sheet layer a VP does not display an object, even with all classes visible. Entering VP annotaion the object becomes visible but is not selectable by picking, or window, alt or not, or select all. If the object's class is not visible in the VP would it be visible in the annotation thereof? Me thinks, of course not. I know its likely a class issue, Ray, but what class issue? Thin hair, getting thinner. Quote Link to comment
Travis Posted March 24, 2008 Share Posted March 24, 2008 Brooke, Check your "global" class settings (Navigation pallet). It sounds like you've got the class(es) turned on for the VP, but you don't have some critical class(es) active overall. HTH Quote Link to comment
Jonathan Pickup Posted March 24, 2008 Share Posted March 24, 2008 there are class settings on the Object Info Palette for each ViewPort. Check this. Quote Link to comment
Brooke Posted March 25, 2008 Author Share Posted March 25, 2008 I tried to clarify that both the VP class settings and the sheet layer class settings were 'show, snap, modify all.' If that's all we got, I'm stumped and have re-drawn the unselectable objects, but will come back when such happens again. Thanks. Quote Link to comment
