Problem with worksheets/clipboard?
markj
Here is another mystifying anomaly with vw2008;
I have some custom made tools which draw objects, and then write a record into a worksheet to create an object count/item list.
The bit that does this is;-
setrecord(LnewObj,rfs);
SetRfield(Lnewobj,rfs,'Item Code','POST/TS/W');
SetRfield(Lnewobj,rfs,'Description','Tall Post-Square, Wood');
SetRfield(Lnewobj,rfs,'Material','Wood');
The thing all works fine (& always has done!)and fills out the worksheet properly. The problem arises when I try & export the data. When I copy the columns from the worksheet & paste them into an excel spreadsheet, I get an extra blank line between each line of data, which messes up the excel calculation.
To make sure it is not an excel problem, I paste the worksheet columns into a word document - you get the same double line spacing. If I paste into notepad it works fine, with no extra lines. Incidentally the 'Export Data' function works OK, and writes a notepad document correctly also. Pasting into a google spreadsheet also produce the double line spacing.
This problem only seems to happen with vw2008 on a PC. It was OK with v12.5, and doesn't cause any problems with a mac.
Any ideas where the problem lies?
Thanks
Mark
Hi Mark,
Thank you for pointing this out.
This looks like a text encoding bug in the clipboard. There is nothing wrong on your side.
Use the "Export Worksheet" command for now.
Thanks
Hugues
NNA
Thanks for looking! - The 'Export Worksheet' & 'Import Data' into Excel is longwinded & a pain, especially if there are several worksheets on the drawing. It is so much easier to simply copy & paste the data direct. I guess I'll have to copy & paste into notepad and then copy & paste from there into the excel sheet, (which sort of defeats the object of our rather nifty CAD/Excel system!).
Thanks again
Mark
