Door & Window Part Line Styles
"Special Classes" works when rendered (how does it work in wireframe?). But checking "Use Part Line Styles" still has no effect.
I'm a little confused--"this is probably what you were doing" is correct, but implies I should be doing something else.
Thanks in advance.
MacBookPro 2.33GHz/2GB RAM
Mac OS 10.5.2
VectorWorks Architect 2008/RW SP2
I think I figured it out. The door/window pen attribute for style and thickness have to be set to NOT be the class style (or, referring to blackdogarch, "Use At Creation" should be UNCHECKED). Then "Use Part Line Styles" works. Why this additional step is necessary is mysterious to me (ie why can't "Use..." just override the class attributes?).
Mac OS 10.5.2
