Can't draw walls
I've investigated this further. If I import a wall style that works in another drawing then I can draw walls in the affected drawing. I still don't understand what happened to the walls I'm trying to draw with the styles that are supposed to be in the drawing (including unstyled). Seems an awful messy thing to me.
It takes a bit at firts to get to understand the layer/class concepts and flexibility. I think of it as the Layer is the Place (Floor, Roof, Slab etc) and Class is the Thing (millwork, window, wall) on that Layer. Jonathan's point is excellent. When in doubt, turn everything on and see what you get. It's easy to put things in the wrong place.
