mm Posted March 12, 2008 Share Posted March 12, 2008 I have a viewport that is twice the scale of the original plan. I can't figure out how to have the dimensions of the viewport read at the same standard 14 pt. font size as the original plan. Notes can be shown on the viewports at 14 pt but not the dimensions. Can viewports not be used to show "detail" plans with dimensions? Quote Link to comment
Pat Stanford Posted March 12, 2008 Share Posted March 12, 2008 Select the Advanced Properties button at the bottom of the Object Info Palette (with the Viewport selected). Set the text scale to the Viewport Scale Divided by the Design Layer Scale and you will get the text to display the same in both places. The same applies to the other settings, but may or may not be needed depending on your output devices and resolution. Pat Quote Link to comment
mm Posted March 12, 2008 Author Share Posted March 12, 2008 That worked . Thanks Quote Link to comment
