Kimcz Posted February 27, 2008 Share Posted February 27, 2008 VW 11.5 suddenly crashed, and then all file names were changed to the old 8 letter max system. After rebooting several times, it will not change back. Is there a switch somewhere in the options/preferences, or must I reinstall, which will be a bind as I have customised my workspace? Has anybody had the same experience? Quote Link to comment
islandmon Posted February 27, 2008 Share Posted February 27, 2008 Normally, the FileNameLength is handled by the OS. Windows has a property option to use the old 8 character DOS filenaming conventions. The FileNameLength is linked to the Type/Creator declaration via OS Properties. Try checking your OS FileName Preference Settings for Vectorworks file type "DO11", creator "CDP3" . Quote Link to comment
travlnjack Posted February 27, 2008 Share Posted February 27, 2008 i am having the same problem. and, there are no file types DO11 or CDP3 on my system; my version is 11.5. anybody else have any ideas? Quote Link to comment
luisc Posted March 5, 2008 Share Posted March 5, 2008 same thing happened after a VW crash the other day, on PC and XP using VW 11.5, any luck in solving this problem? Kimcz and Clay what platform are you on? I assume that islandmon is on Macs, given that file type "D011" and creator "CDP3" are Mac way of identifing a VW files Quote Link to comment
luisc Posted March 6, 2008 Share Posted March 6, 2008 I found the problem, its the latest version of Quicktime 7.4.1, I unistalled it and installed an earlier version of Quicktime and VW 11.5 shows the file names the correct way. Quote Link to comment
Kimcz Posted March 10, 2008 Author Share Posted March 10, 2008 Luis, That's it! Problem solved. There had to be some answer. Thanks for your imput Quote Link to comment
