Ride Posted February 25, 2008 Share Posted February 25, 2008 Just wondering if anyone has had this problem. Whenever I try to edit text I've created, it is not visible on the screen. All I get is a grey box with the tab markers at the top where the characters are located, but I can't see the text. I've also noticed that the text I'm trying to edit is actually visible, but somewhere else on the screen; usually way off to the right (and often too far to see clearly). Forces me to be a better typer tho cause trying to fix errors later are tough. Quote Link to comment
Benson Shaw Posted February 25, 2008 Share Posted February 25, 2008 Hi, Ride - Make yourself a signature with VectorWorks and system info. It helps troubleshooting. Text shows as a grey box if you are zoomed out too far. Try getting closer with the zoom tool or select it and use the Zoom to Object command, and report back. Or, you may have a text size which is too small for the scale of the layer you are working on. To test this, open a new VW drawing and make some text. If the text is a grey box, Zoom in on it to see if it is actually a working text box. Then try reducing the layer scale (disable the Scale Text option in File/Document Preferences/Document Settings/Scale) or increase the text size using the Object Info Palette. To set the drawing default text size click in a blank area to deselect everything, then mouse up to Main Menu/Text/Size and select a different (bigger) size. Sometimes, imported dwg text block bounndaries have HUGE, almost infinite size, even though there are only a few words in them. The selected text may have a starting locus on the left side, and an end locus way off the drawing window to the right. I guess this could happen with a new VW text block, too, but I have never seen it. Let us know some of the drawing settings where this is a problem. -B Quote Link to comment
Ride Posted February 26, 2008 Author Share Posted February 26, 2008 Thanks for the reply Benson. I don't think its a zoom or scale issue. I've been using VW for about 2 years now, and this seems to be a new problem. Funny thing, when I open a new file, I can see the text I want to edit. The problem arrives only after I save the file. Actually, I've had a lot of glitches with VW lately. I might try a re-install (and this will be the 3rd time since upgrading to 2008). I question how much testing Nemetschek actually did on 2008 before its release. I won't be so quick to upgrade next time a new version is released that's for sure. Any other help would be great. VW 2008SP2 on Macbook Pro/Leopard Quote Link to comment
Benson Shaw Posted February 26, 2008 Share Posted February 26, 2008 mmm Bummer, Dude. 3 reinstalls of 2008? What you are reporting is unique. I'm out of ideas. Post again when you figure it out. -B Quote Link to comment
Ray Libby Posted February 26, 2008 Share Posted February 26, 2008 Are you creating your text box by clicking and dragging? If so try just clicking once to create text. I believe this was a known bug. What build number are you using?. It's listed under Help menu>About VectorWorks. Benson's advice on creating a signature is good, click on the My Stuff link at the top, then my profile. Using a signature will include your specs with every post. Include VectorWorks version including build number, system specs including OS version. The more detailed the easier it is for others to help. Quote Link to comment
konrad Posted February 26, 2008 Share Posted February 26, 2008 I?ve got the same problem, the text appears far right and down from where I clicked, but not only when I am editing even when I create the text. This bug appears without any noticeable reason. Solving the problem would be very helpful! K. Quote Link to comment
Guest Donne Martin Posted February 26, 2008 Share Posted February 26, 2008 (edited) Hi Ride and Konrad, Try setting the data bar options to one of these two and let me know if it has any effect: -Use floating data bar -Use floating data bar only when tab key is pressed You'll have to close, reopen, and work on the file some more to see if this solution works. Thanks Donne Edited February 26, 2008 by Donne Martin (NNA) Quote Link to comment
Ride Posted February 26, 2008 Author Share Posted February 26, 2008 I used the option - Use floating data bar. This seems to have worked. (I prefer not to use the floating data bar, but it's preferable than not seeing my text!) I will try further and let you know of any problems. Thank you. This was driving me crazy. BTW, I created my text boxes by clicking (not by dragging a box), and I'm using build 83388. Thanks again. VW2008 SP2 83388 on Macbook Pro / Leopard Quote Link to comment
konrad Posted March 4, 2008 Share Posted March 4, 2008 Hi! I tried with both suggested settings and it seems to work! Thanks a lot! Konrad Quote Link to comment
Lila Posted March 27, 2008 Share Posted March 27, 2008 greetings everybody, I recently upgraded from 11.5 to 2008. I've just registered because I am experiencing the same text problem and it's driving me CRAZY. I have been using MiniCad and VectorWorks for more than 10 years and have never had this problem. It seems the text input and edit functions flake out with no rhyme or reason - it's very erratic. I find I have to quit and restart Vectorworks in order to edit my text. It's really eating into my productivity. Though I'm glad to find I'm not crazy and that others have been having the same problem, I really need a solution. I'm not fond of the floating data bar, but I'll give it a try until a repair for this problem is developed. Thanks to everyone for your suggestions and I hope to use this forum again in the future. Quote Link to comment
Ray Libby Posted March 27, 2008 Share Posted March 27, 2008 Have you updated to SP2? Quote Link to comment
Lila Posted March 27, 2008 Share Posted March 27, 2008 Ray, I have updated, but a quick check indicates there is an update to SP2 that I don't have. I will be installing it now. This issue is not listed in the fixes, but with luck it will help. Thanks for the heads up. Quote Link to comment
Guest Donne Martin Posted March 27, 2008 Share Posted March 27, 2008 Hi Lila, Enabling the floating data bar (either through tab or by having it always show up) seems to be the workaround. We hope to have the fix in an upcoming service pack. Donne Quote Link to comment
AJN Posted April 4, 2008 Share Posted April 4, 2008 I've had the same text problem. Enabling the floating bar seemed to do the trick. I also hope vectorworks is able to address this in the next service pack. Quote Link to comment
