David L Posted February 24, 2008 Share Posted February 24, 2008 The following is a VectorScript for setting an attribute for one or more selected objects. It uses the "ForEachObjectInLayer" procedure which is very powerful and customizable. It can do, in one line of code, what it would take many other lines of code to do. This script can be applied to setting almost any attribute for selected objects. The best use for it is to create a menu command from the script and assign it a key command (See Robert Anderson's "What do I do with a VectorScript, anyway?" in this topic). That way you can select some objects and type a key command to change their attributes (line weight, dash, fill, pattern, etc.). To set other attributes enter the procedure(s) you want in the "FUNCTION FillObject" subroutine. You can customize what objects are worked on by adjusting the parameters in the "ForEachObjectInLayer" procedure. Using the Constant for entering the attribute parameter makes is easier to create multiple copies for each line weight or other attribute. This script also sets the default attribute for the drawing if no objects are selected. If you don't want it to do that, delete all of the lines with countObj in them. Please copy everything including the comments if you distribute this script. {=================================================================== ??This script sets the line weight of the user-selected object(s) ??to value indicated for the CONSTANT - w. ??If no objects are selected the default fill pattern is set to the ??CONSTANT value. ??This Vectorscript may be freely distributed. No warranty ??provided. Use at your own risk. David LaBarbera, 2008 ====================================================================} PROCEDURE SelectedObjLineWeight; CONST ???w = 2; { <----------- Line weight in mils.} VAR ???countObj : INTEGER; FUNCTION FillObject(h:HANDLE) :BOOLEAN; BEGIN ???SetLW(h, w); ???countObj := countObj + 1; END; {---IF selected objects exist, they will be ????counted each time Function above is called} BEGIN ???countObj := 0; ???ForEachObjectInLayer(FillObject, 2, 1, 4); {---IF no objects are selected, then default fill pattern is set} ???IF countObj = 0 THEN PenSize(w); END; Run(SelectedObjLineWeight); {========================================================================== ForEachObjectInLayer(Function Call; objOptions; travOptions; layerOptions) Object Options 0 = All objects 1 = Visible Objects only 2 = Selected Objects only 4 = Unlocked objects only Traversal Options 0 = Traverse Shallow 1 = Traverse Groups 2 = Traverse Deep Layer Options 0 = Current layer 1 = All layers 2 = Visible layers 4 = Editable layers 8 = Snappable layers ===========================================================================} Quote Link to comment
David L Posted February 25, 2008 Author Share Posted February 25, 2008 After reading Pat Stanford's script "Rotate objects by individual centers" I discovered the Count procedure, so I revised the script. Now it is basically only 3 lines of functioning code. {=================================================================== ??This script sets the line weight of the user-selected object(s) ??to value indicated for the CONSTANT - w. ??If no objects are selected the default fill pattern is set to the ??CONSTANT value. ??This Vectorscript may be freely distributed. No warranty ??provided. Use at your own risk. David LaBarbera, 2008 ====================================================================} PROCEDURE SelectedObjLineWeight; CONST ???w = 2; { <----------- Line weight in mils.} FUNCTION FillObject(h:HANDLE) :BOOLEAN; BEGIN ???SetLW(h, w); END; BEGIN ???ForEachObjectInLayer(FillObject, 2, 1, 4); {---IF no objects are selected, then default attribute is set} ???IF Count(SEL=TRUE) = 0 THEN PenSize(w); END; Run(SelectedObjLineWeight); {========================================================================== ForEachObjectInLayer(Function Call; objOptions; travOptions; layerOptions) Object Options 0 = All objects 1 = Visible Objects only 2 = Selected Objects only 4 = Unlocked objects only Traversal Options 0 = Traverse Shallow 1 = Traverse Groups 2 = Traverse Deep Layer Options 0 = Current layer 1 = All layers 2 = Visible layers 4 = Editable layers 8 = Snappable layers ===========================================================================} Quote Link to comment
