sketcher Posted February 21, 2008 Share Posted February 21, 2008 any recommendations for a "dummies" guide for starting with VW 2008? Also is there any way to remove the X,Y coordinates? the ones that show up as you're drawing a shape Thanx in advance ps get ready, we're getting VW at work and im sure i will be relying on you folks a bit Quote Link to comment
MullinRJ Posted February 21, 2008 Share Posted February 21, 2008 In the upper right hand corner of the drawing window, second little black triangle down from the top, select the option that says "Use floating data bar only when tab key is pressed" or one of the next two selections. Welcome to VectorWorks Land. Raymond Quote Link to comment
