lostboy
3d Points
I have been trying to figure this one out for a while. I'm trying to pull data out of Vectorworks, initially wall data.
I need the 3d co-ordinates of all external points of a wall. I have figured out a few methods to use, such as Get2dPt(), which will give me the start and end, and I can get the height to figure a few things out.
This doesn't help me when the panel is an odd shape, and not rectangular, which would be quite common.
I have searched through the Function Reference a few times, and have been unable to find anything to give me this data.
Try this neat trick ... just write a script to do this :
1) Create a WALL
2) Convert it into 3dPolys
3) Export Vectorscript
here's the result for a Wall duplicated & converted:
{Object Creation Code}
NameClass('None');
SetZVals(0",5'0");
DoubLines(1'0.000000000000002");
ClearCavities;
PenSize(1);
PenPat(2);
AddCavity(FALSE,0",0",0);
FillPat(1);
PenFore(0,0,0);
PenBack(65535,65535,65535);
FillFore(0,0,0);
FillBack(65535,65535,65535);
Wall(0",0",10'0",0");
WallCap(FALSE,TRUE,FALSE,0",0");
WallCap(TRUE,TRUE,FALSE,0",0");
{the 3dPoly data of interest }
BeginGroup;
ClosePoly;
Poly3D(
0",10'6.000000000000002",0",
10'0",10'6.000000000000002",0",
10'0",9'6.000000000000002",0",
Poly3D(
0",10'6.000000000000002",5'0",
0",9'6.000000000000002",5'0"
Poly3D(
10'0",10'6.000000000000002",5'0",
10'0",9'6.000000000000002",5'0",
Poly3D(
Poly3D(
Poly3D(
EndGroup;
Check out the section of the VS Function Reference on Object-Walls.
GetWallPeaks and GetNumWallPeaks will get you a lot of information on non rectangular walls.
Pat
